Wipers stopped working Fabia VRS...help
I've done a search under "Windscreen wipers not working" and come accross something about fuse 15 blowing?
Anyway, come to my car this morning 05 Black Fabia VRS and the windscreen wipers arent working, I done an goodle search and found something on fuse 21.
Checked the fuse, shock.....nothing in fuse slot 21, not even connections for it.
Ok, the rear is working(jet isnt but I know that the hose has popped off in the enginebay somewhere so I'm not too worried about that)....nothing ref: the front wipers is working......Help.
I've had a look in the manual and it isnt too clear which fuse beyond 21(heated jets) it could be.
Unless it could be a relay(where is it)??
As we have rain forcast up north I could do with some direction on what to checkout outside of taking each fuse out individually and checking them.
Carl
Keep in mind the fuse box in the manual is the wrong way round (clever, aint it)..
fabia-vrs.com has a correctly drawn one i think.
There are about 3 fuses for the wipers..
Check out the pinned thread in Fabia 1.. should hopefully tell you all you need to know :)
bear in mind the diagram in the manual is for a LHD car so positions are actually reversed which is why you found a blank hole where 21 should be
did you actually check fuse 15 as well as 21?
this threadmay hold the answers
Edited by PastyBoy
