How do the front Fog lights fasten in ?
Bought these today
Two sets for £21 .. Thought that was a very good price for Gen VW ;)
So i plan to fit these but i am left wondering how the Fog lights Fasten in ?? (I don't have the Fogs yet or another Vrs to Compare)
Many Thanks.
Dean
Edited by dfullb
Two screws I believe! WIll try find a pic...
Don't know id that's any good?
Might be able to zoom in! :)
2 screws that secure the foglight, Screwed in from above, So it's a bumper off job!
The surrounds simply snap into place.
Well, Fitted the inserts tonight.. A liitle Modification was req because the Bumper had already been cut back for the Mesh...
Not the Best of Pics as it was dark & off my Phone.. But i think it looks better & will improve once i get some Fogs :D
Before
After
Dean
Looks good B)
I had to replace a broken fog light on my vRS, it is a bumper off job I'm afraid, a few screws at the front of each wheel arch remove these, 3 locking grommets under the bumper, using a punch or srewdriver to gently push the centre bit nearly out then you can pull the grommets out, next grab hold of the bumper in the wheel arch just under where it meets the wing and pull it out, controlled aggresion required to pull it out of the locking tabs, do this for both sides. Under the bonnet the bumper is attached to the front valance with 2 screws, remove these and the bumper will pull out, there will be a sensor bolted to the bumper, unbolt this and the whole unit will pull away, good luck .
Cheers All :thumbup:
Your all Stars ...
Dean
Dean, out of interest, do you have to buy the body colored bit and the black bit together? Or can you buy the black non painted bit separately?
And if ya can, does your invoice say how much?
I ask because mine are looking quite tired after 62k.
Wouldn't be a problem normally but on a black car it's quite obvious they're fading and loosing their finish.
Hi Rob.
No. You can buy them separately. I'll dig out the P/No & price when i get back home emoticon-0105-wink.gif
Cheers.
Dean
Not sure which Bits relate to which p/No as i have thrown away the original packaging :D
But no doubt somebody will be able to assist ....
6Y0853683AB41 Cover For RRP £6.31
6Y0853684AB41 Cover For RRP £6.31
6Y0853655A Cover RRP £3.51
6Y0853656A Cover RRP £3.51
Hope this helps .
Cheers.
Dean
Thanks Dead, much appreciated. :D
I'll pop one of mine off and see what numbers are stamped on them, can work out the price per part then.
Thanks Again,
Edited by Rob.
