Central Vents problems
hi Octavia fans....
I have the following problem, mi central vents of my octavia II are stuck... my kids put a little ball inside....
I have to remove the complete central vent to repair it. I try very gently but don't discover how to doit... can anyone know how?
Thank you in advance.....
Marcelo (Chile)
A lo mejor puedes sacar la pelota con un tubo chico unido a la manguera de una aspiradora?
hi Octavia fans....
Marcelo (Chile)
You can prise the vent out quite easily, start at the bottom sides. It will seam as if it is not going to come out then it will come all of a sudden, then you can push the hazzard light button out from the inside then you free to remove what ever.
Good luck!
it comes out as one complete unit, using a long flat implement wedge it in the lower edge under the hazard switch and prise it up gently. Once lifted a little, grasp the unit with your hands and lift vertically. using the back edge as a hinge. When removing watchout for the hazard switch wiring.
