Replace Disks & Pads
Hi
Re Octavia Mk2 1.6 FSI Sep05 reg
At my last sevice I was advised that my disks & pads need changing all round. I have just been quoted £391 for the job at a local Skoda agent, so was thinking of doing it myself. Can anyone recommend a supplier? I have seen some cheap prices but am concerned about quality. Also I have been advised I need a windback tool for the rears - I have seen a standard draper tool at £15 anyone know if it would be ok? Just thought I check these things out before making a mess of things!
Pagid pads which are available from eurocar spares and many other places are as good, if not better than OEM spec pads (I believe some VAG OEM pads are actually made by pagid)
eurocarparts sell good quality cheap gear and ive found this seller on ebay he sells standard brembo discs which are good quality
brembo discs
ok so pagid it is...
My service schedule booklet quotes BLF if thats any help
Looking at Euro Car Parts for Pagid disks shows two front disk part numbers for my model, both quoting BLF: 104441238 described as 22/25mm, and 104441228 described as 19/22mm. Looks like they are quoting the min/max thickness of the disk?
So how do I determine the correct part number to fit without knowing how thick my disks should be?
Similar problems also on selection of rear disks.
Edited by KeithJR
