ARS button...
...in my brand new second hand Octy. What does it do?
What a lovely car to drive by the way, thanks for all the help in deciding which car to choose. Much appreciated.
asr i think you mean??? its used to cut power when it see's you loose traction to a wheels for more than a certain period of time and it closes the throttle body and you loose all power
inho turn it off as it is dangerous to have on and i always have mine off and so do alot of other people
Mine nearly killed me last week pulling out of a t-junction into a NSL. I forgot to turn it off and blimey - it is so dangerous!
Lord what a strange function that is. Cheers lads, once again much appreciated.
One of my favourite ever thread titles - even better than MDF3 stereos :thumbup:
:rofl:
what does it actually stand for?
ARS = Atrocious Rectile Sloppiness
ASR = Anti Slip Regulation
I think :(
Ignore the vRS drivers about how "dangerous" ASR is. On the TDi110 it's a little over-sensitive (fires before the ISF tyre actually loses traction) when pulling away, but just chokes off power to what the tyres can handle, plus it goes away as soon as you start straightening up.
I admit to being a little heavy footed at times Ken, but on mine it seems to be an ON/OFF switch in terms of power. In the instance I had last week, it decided to kill the power for at least four or five seconds. This is an age when people are bearing down on you at 60mph plus. The junction in question is one of those where no matter how fast your reactions, when you commit to go, you have to go for it. I normally turn it off as I've had a few scary moments where the ASR thinks it knows better than me what should be happening, when in fact it doesn't.
Once rolling, it's not so bad, but still a very basic and antiquated system.
I've never really bothered turning mine off, I've found its easier to pull away in snow with it off though, the wheels do spin briefly but then they grip and go instead of it just killing all the power. also the traction control light being permanently on is a sign of a failed ABS sensor (and sometimes problems with the MAF) so if the light's on all the time you wouldn't notice that.
Edited by chicken_eyebrow
On the vRS it kills power, i.e. you have no drive at all.
It's very dangerous, and should be left off!
I'm glad you said that too Babs. Perhaps it's set up differently on other models as it doesn't sound as agressive or intrusive as on the vRS. Mind you, it could just be that us vRS drivers are a set of hoologans with no finesse at all, merely a lead-lined right foot. :rofl:
Haha!
My problem with it, was that I could detect the wheel was spinning faster, and thus adjust my foot. But I did that, then the ASR decided to kill the throttle as well! :dull:
Possibly the Octavia is more likely to lose grip at the front wheels because of the larger and heavier rear end than say a Mk4 Golf or a Seat Leon?
Guys, all I'm saying is that it's a much more benign system on the TDis. This suggests that the problem on the vRS is probably calibration, or maybe you are just a crowd of rock-apes? :)
worked wonders in the recent snow
I probably fit into this category. :yes:
