Very low FE
i think i found the problem to my very low FE
the timing chain is very loose, posibly even with a lot of retarded timing, retarded timing on the valve guives low FE a no torque
i have a air gap where the manifold meets the engine, old seals i guess, wich is guiving me a lean mix, when i adjust the carb to be ok at idle i get almost ok mix at idle and rich mix above idle....
solution
fit timing chanin kit and adjust valve timing to the correct advance
remove manifold and fit new seals
will take the time to pop the head and fit a new gasket and to clean out everything
will post in a month
Sort of makes sense; a really slack timing chain and hooked sprockets (The teeth wear from being symmetrical into a sort of shallow hook shape, hence the name) could put your cam timing out. If the car takes its ignition timing off the camshaft, that will then be out too.
