Hi from the Isle of Wight
Hi guys, my name is Sam, I'm 22 years old and live on the Isle of Wight.
I currently have two cars, a 2.2 Pulsar GTi-R and a '98 Spec JDM DC2 Integra Type-R as my daily. I'm looking to sell my Integra in favour of an Octavia vRS as I had a quick go in a mate's and was pleasantly impressed. Here's a brief overview of my Pulsar which is my pride and joy;
She's got a Tomei 2.2 Stroker Kit running 395bhp and 411ft/lbs @ 1.7BAR on a GT28RS turbo. I have since decided to go forward with a complete respray in W83 Scotia White with new rear arches and am going for a 500+bhp build using a Garrett GT3076R-EWG. Below is a quick spec of the car and a couple of photos before she went in for her respray;
Engine/Power/Drive
- Tomei SR22 Full-Counter Crank
- Tomei SR22 Forged Piston Kit
- Tomei Forged H-Beam Conrods
- Tomei SR20 Procam (272)
- Tomei SR20 Cam Gear
- Tomei SR20 Pulleys
- Tomei Titanium Top Rings
- Tomei SR20 Double Valve Springs
- Tomei Retainers
- Tomei Lifters
- Tomei Spring Sheets
- Tomei SR20 Solid Pivots
- Tomei SR20 Shims
- Tomei SR20 Valve Guides
- Tomei Head Studs
- Tomei Main Studs
- Tomei Rod Studs
- Tomei Rocker Stopper Kit
- RB26 ACL Big End Bearings
- RB26 ACL Main Bearings
- RB26 ACL Thrust Bearings
- Uprated Flywheel
- Uprated Flywheel Bolts
- Cometic Headgasket
- Head Port
- Head Polish
- Head Skim
- Head Gasflowed
- Inlet Port
- Inlet Polish
- JapSpeed Spec 2 Exhaust Manifold (Custom Braces & Bracket)
- 1mm Oversize Inlet Valves
- 1mm Oversize Exhaust Valves
- 3-Way Cut Valve Seats
- Acid Dip Block
- Deck Block
- Polish & Re-Hone Bores
- Blueprint Bottom End
- Balance Bottom End
- New Gearbox
- Uprated Selector Fork
- Complete Gasket Set
- New Water Pump
- New Oil Pump
- New Timing Chain
- Uprated Pressure Plate
- AP Twin-Paddle Clutch
- B&M Short Shifter
- 4x NGK Iridium BCR8ES Plugs
- MSD 6a Ignition Box
- SS Blaster Coil
- RC Engineering 1000cc Injectors
- Sard FPR & Gauge
- Garrett GT3076R-EWG Turbo
- Tial 44mm External Wastegate & V-Band Screamer Pipe
- Forge Front-Mounted Intercooler
- Bailey Oil-Catch Can
- Pro-Alloy Radiator
- Turbosmart BOV (Recirc Disconnected)
- Z32 AFM
- Walbro 255lph HP In-Tank Fuel Pump
- Bosch 044 In-Line Fuel Pump
- APEX'i Power Intake Filter
- Mongoose Turbo-Back Exhaust (5" Tail)
Management/Diagnostic/Security
- APEX'i Power FC Pro (Inc. Commander)
- APEX'i AVCR
- APEX'i EL2 2bar Boost Gauge
- GReddy Turbo Timer
- Clifford Full Closure Alarm (Proximity Inc.)
- RAYS Lightweight Wheel Nuts
Handling/Suspension/Wheels
- Lowered 20mm (Springs)
- Rear Suspension Strut Kit
- New Front Shocks
- Front Strut Brace
- GAB Adjustable Rear Strut Brace
- Recent 4-Wheel Alignment
- League 111 Bandit LR-01R 16" Alloys (~6kg)
- Wilwood 4-Pot Front Brake Conversion (310mm Discs)
- Yellow Stuff Pads
Interior/Exterior
- Battery Relocated (Boot)
- Stripped
- Lockwood White Dials
- Carbon Wrapped Filler Cap
- Carbon Wrapped A-Pillar Trims
- Chrome Expansion Tank
- Forge Power Steering Tank
- Polished Fuse Box Covers
- Stainless Plug Cover
- Stainless Oil Filler Cap
- Sound Deadening Removed
- Momo Steering Wheel
- Alloy Pedals
- De-Tango'd Front Lights
- De-Tango'd Rear Lights
- Clear Side Repeaters
- Blue Samco Silicone Hose Kit
- Auto-Folding Mirrors
Here's how she looks now;
A brief video of her first startup after the respray can be seen here;
I look forward to seeing all the forum has to offer and being a part of the community.
Sam
Edited by Smo
welcome to briskoda nice car :thumbup:
Hello Sam from a fellow Isle of Wighter. I too frequent evocars (DAN K) :thumbup:
