Brake Warning Light and 3 peeps after brake change!
So........ I have upgraded the brakes to 312mm this morning, calipers and discs no problems, on the in-augural test run I start the car and the brake warning light is on (and I get three peeps) the manual says that the brake fluid is to low....but this is not the case! I am a bit flummoxed???
Everything was going so smoothly! Do I have to bleed the master cylinder do you think....I cannot think why the warning light should come on - min loss of brake fluid (ie none!) bled correctly, brakes work - so what gives!
That usually is a low fluid warning. Try topping it up a little..
Kev
It is right on the Max level!
