1.4 mpi Fabia cylinder head gasket
Hi
Am changing head gasket and Haynes manual say,s you can reuse the stretch bolts everyone else says no, steel on bolts is quite hard and considering it is a alloy block surely that has more chance of that stretching not the bolts plus bolts were not even torqued to 1st stage torque of 20 nm [tested before I removed them [4 off] ] so anybody with views or experience of this job .
Two things:
1st, they're not stretch bolts, so you can reuse them.
2nd, it's quite possible to have stretch bolts with an alloy engine.
Two things:
Hi
Thanks for info
yup just reuse them.. the headbolts are not stretch
