ESP IS ON FABIA VRS
HELLO Can somebody save my a fortune and tell me how to turn my ESP of and my ABS of ,First thing that happened is the ESP light switch on and stayed on then when braking i can feel the brake pedal judder when pressed hard ? :'( cheeked my brake pads to find the back ones need replacing thought this would solve the problem :S sill the same ?
If you have ESP, there is a button on the dash, if you don't it's an ASR button and if the light is on all the time you could have other issues and you need to get your codes read.
Why you would want to get it turned off is a mystery, you need to get the issue fixed rather than stick a plaster over it. It's like using pit spray when you need a shower.
Edited by Decron
