Electrical suppressor
Hi everyone,
i have installed some sound equipment in my car and have a "wine" and bass click that speeds up with the press of the accelerator.
I have tried the ground cable in various places and then ran a cable direct to the battery. no change.
it doesn't make the wine or bass click with the engine off. So, I'm led to believe its EMI and i need a suppressor.
I have no idea about this and apparently there various sizes and places to put them. Does anyone know what kind i need for a MK1 Octavia T reg?
Any ideas or suggestions greatly appreciated.
thanks,
Dryden
Edited by DRYDEN
Hi,
Are you running the power cable and the audio cable next to each other through the car? This would cause a wine with acceleration.
as above, power cables should be run down 1 side of the car and speaker wires down the other. also check the length of the wires especially the earth lead as these should be as short as possible :thumbup:
or have a read of rob's latest addition this should help http://briskoda.net/forums/topic/159933-grounding-kit/ B)
HTH
Edited by sivrs
Hi,
I am running them together, but I did test if that was the cause by removing the power cable from the battery and amp and attached a seperate wire and ran it around the outside of the car and it still made the whine.
