brake upgrade help 256 to 288 hub issues!
hi to you all!
i need help from someone who has done a hub upgrade pd110 hub to pd130 hub
the problem i have is that my abs sensor have different connectors and a differnet length and are in a differnet place on the hub!
if i dont connect the abs sensors the speedo does not work and the fuel gauge is intermitent connect the old ones and all is ok!
i believe the pd130 has a gearbox speed sensor but mine seems to be of the abs sensor?
so how did you get round this problem? did you have this problem?
did you cut and splice the wires from one connector to the other?
any help would be great
i have a pd100 ibiza 03reg and the hubs i have are of 03reg
I have fitted vRS Fabia hubs to my non vRS fabia and all sensors hooked up in the same place with no issues at all. Cannot suggest what to do in this case - Can you cut & shut the wiring loom to allow the sensor to go in the new hole?
hi im not sure as it seems more than just an abs sensor but i will have a look before butchering it! lol
i have the wire that came of the 288mm hub sensor so will try to connect it in and see if the speedo stops again
can i ask does you car have traction control and what year? as mine has not. you wolud think it would be the same, well hope
