is the turbo going (gone)?
hi
i have an 04 vrs fabia and its symptoms are:
smoke before it warms up
oil leaking(from one of the turbo pipes i think)
a whine.
suspected the turbo and got a mechanic to take it off. on inspection he says its moving freely without any play.
what else could be causing this??
any help appreciated
What Colour Smoke ?
Could be a Boost leak, Has it lost power ?
They All weep/leak oil from the Vag Boost hose's due to the Crank case breather system recirculating it back through ...
They can all have a bit of a whine/whistle also, If it is V loud or sounds like a Police Siren then it sounds like Journal bearings.
If not, i would listen to a few others & compare ..
Dean
Edited by dfullb
The smoke would be a blue shade when u hit the turbo. ( only when car is cold) when it warms i dnt think there is as much smoke.
boost leak!!
youve already identified your problem!! a leaky intercooler hose!!
replace this then give it an italian tune up!!
smoke will just be due to the leak
