Quick Question
You know the splined bit that you need to remove the Fabia seats??
Where can I get one, and any idea on cost (though, i'll be buying it regardless).
Rob.
Try ebay or halfords will be your best bet because you will be able to show them the bolt to get the correct size
Matt
torx
3/8 sets bit cheaper and individual ones bout 4 quid a piece.
torx on ebay
cheaper on ebay if you've an account.
Hmmmm, I'm quite close to a dealer.. might just ask them to loosen them to finger tight.. and then tighten them back up once I'm done..
Don't think they're torx bit's. I've got a set of those. The ones holding the seats down are much bigger and have about 12 splines.. Think anewman is right with the XZN bits.
Edited by Rob.
