Secondary air pump
Ok it appears mine has a life of its own,
Neighour woke me at 5am yesterday when she was going to work saying it was making a noise by time I got some trousers on it couldnt be heard until this morning when I walked past the car and the pump started all by itself, I didnt even have the keys with me :o .
Later got into car to go to work after I got there turned off engine and then pump kept going, quick fiddle under the bonnet found some relays I pulled one and it stopped put it back in and it started again so whipped it out again.
Only thing I have noticed driving it home this evening was the engine check light coming on thought B***X whats going on and then remebered I had took a relay out.
Question is has the relay gone kaputski? am I doing any harm driving it without the relay in it?
(Relay removed was in engine bay up by bulkhead on side near MAF relay on the left of the 2 think its got a number 100 on it)
Cheers Peeps
Edited by Bodie
the check light has come on because the relay has been removed so sees a loss of air
this will cause no harm just annoying that the check light will come on
option 1 remove pump and put a resistor in the wiring job done no cel light and no annoying pump any more :thumbup:
got a duff shoulder at mo so think option 1 will be new relay until shoulder improves a lot :thumbdown:
As far as I know a resistor won't do it. I had to get my CEL mapped out
is it one resistor for removing this
yes mate just fasten into the connector plug :thumbup:
fantastic got one in the post today just got to buy the blanking plate
si you legend mate email sent fantastic timing
no probs mate :thumbup:
anything i should know before i start ive read robs guide tho
no mate its all straight forward, the only thing i left was the bracket that holds the pump on as i didnt have an allen key socket at the time. other than that its all good :thumbup:
fantastic and the rest of the system rob removed are they just to tidy up or any improvement
