Itunes - windows xp - Help
Now then boys and girls, small problem, when i try burning a cd onto itunes it....
A reads the first 12 tracks correctly but then joins track lengths together ( putting two or Three together) and can't then label it, it has done this to twenty or thirty disks, any clues????
Cheers :confused: :confused:
I'm not sure exactly what you mean from your description. Are you importing the songs from the CD into iTunes (Ripping) or burning your MP3's back onto CD?
If you're importing the CD, there's an option join tracks together to remove the gap inbetween (typically for DJ mix CD's).
From the iTunes Help:
"If you want to remove the gap of silence that normally occurs between songs, select two or more adjacent songs and choose Advanced > Join CD Tracks.
iTunes imports any joined songs as one track. To change back to importing the songs separately, select the joined songs and choose Advanced > Unjoin CD Tracks."
