Ahhhh ABS light has ....
The ABS light on my superb has just come on aswell as the ASR off light. Both in Yellow, now I have not noticed anything different about the cars braking.
Is this an easy fix for me? also will it fail its taxi test because of this light? any help much appreciated.
Model .. 1.9TDI 2006 SUPERB. :smirk:
Pull the sensor's from behind the front brake disc shields and give them a wipe off, and make sure you refit properly.
do you mean the ABS sensors because i thouhgt these were very brittle and break 90% of the time?
They're a push fit in the suspension leg and held in by a spring steel insert. Give it a good squirt of WD40 or a penetrating fluid and let it soak for a bit then gently pull it out by hand then you can clean it.
As they say 'fitting is reversal of removal'
