warning lights and leds
i know that some models don't have them in but i dont seem to have warning lights in my door. is there a way i can wire some up at all :S or get some from somewhere and poss change to leds in the over head interior light ?
Yep LED bulbs will fit in interior light, plenty available on ebay.
I'm not sure it's worth going to the effort of wiring up door lights. I don't believe the wires are already there, so you'd have to remove the big panel covering the electrics under the steering wheel, remove the glovebox, take the door cards off, route wires through, and identify the correct wires. I don't think the benefit would outweigh the effort needed to do it when there are already reflectors there.
lol, ahh sounds like a hell of a lot of work for just some lights actually. good point m8.
thanks for led advice,
also has anyone ever taken apart the speedo cluster and changed the leds in it, have heard about what it involves to do it. but never seen end results, also possible change the white pins over to red ?
what you think?
