Time and presure
When using an orb polisher.. how much presure / time do you spend to remove swirlys?
is it kinda a 10min per panel?
Ive got to start on mine soon, realised swirlys today :(
Depends on the pad and polish combination you are using. General rule is apply pressure so that the pad is rotating roughly twice per second, and move the machine two inches per second across the work area. Mark the pad backing plate with a large larker pen so you can see the rotation rate. Number of passes will depend on the depth of the defects being removed. Keep the work area to about two square foot at a time.
Spread the polish at speed 2 then step up to speed 5 to work the polish.
Edited by MoggyTech
