towbar electrics
hi i have a octavia 2005 fitted a towtar but stumpted by wiring as stop lights + side lights use same 21w single filament bulb
Not sure whether this is a question cunningly disguised as a statement, or vice versa. Either way, I know that if you go on Westfalia's website, there are some pdfs which show the pin layout of their 13-pin sockets. I guess they will also have the same for the 7-pin type too. I believe the standard was revised about 10 years ago. Hope that helps if that's indeed what you wanted to know (or perhaps knew already ?????)
Thank you, yes it was indeed a question, I'll have a look at the suggested website. Thanks again.
thanks jeeves but it is not the 7 pin plug that i cannot understand it is the other end of the cable when it connects to the loom .if i connect to the wire for the brake light it also doubles as a side light wire
