Have I been given the correct oil?
:confused: :confused: I have just got some oil from the garage to do a service on my Octi Vrs. It is on varible servicing but due to the garage wanting
I too am a bit confused on what oil to use... there is a list here which has some oils on, but yours is not on it, and yes it does say 0w 30w
As your car will be on fixed service intervals if you reset the service indicator from the dashboard, your choice of oils is wider. If you want to use a multigrade high lubricity oil rather than a multigrade oil, then any oil meeting spec VW 500 00 (date 11/92 or later) or VW 502 00 (date 01/97 or later) is suitable. The Granville oil should be fine as it meets 500 00.
Cheers for the replys, will put it in and see waht happens :eek:
On the votex vw forums they say that 0w/40 is a good chioce and it seems to make the engine smother, so we shall c :thumbup:
  • Sponsor
0w-30 is the standard grade for these cars, the 0w-40 is popular if you have modded your car and are pushing over stock horse power, Motul and Mobil do very good 0w-40.
I take it your car is out of warranty then?
yes ross it is out of warranty.... :(
I was quoted over
Pop down and see me sometime and i'll set the service schedule up for you if we can. However i think the min mileage you can enter intot he dash insert is 9,300 miles, doesnt accept any lower than that.
And as a little ****er if you had had a 1st variable service at say 15,000 miles. Then went back at 30,000 miles and wanted to put it onto fixed servicing you could have just had a 30k lube service which is just an oil and filter and paid about
LOL, Cheers ross, typical I got c**p help from my garage, are well atleast I can find my way round the engine now :thumbup:
I had alook around the net and on some websites you can use vag-com to set the fixed service schedule to what you like it seems.... I have found on andy whittakers site taht for about
