VIN plate
Not by my car right now but I need to know the most easily accessible place to grab my VIN from so I can order a hose up from the stealer.
Should be on a little plastic plate you can see through the windscreen on the passenger side.
If you can't see that (e.g. if you've had a windscreen fitted without the see through bit) then its on a plate at the back of the engine bay.
...and it may be etched on the windows.
NB, if the windscreen has the clear hole in the black syrround, it may well be directly under the the windscreen wiper in the park position.
Muchos gracias!
