Link arms?
Hi finaly found out what the rattle was!! link arms? or drop links somthing like that anyway!! Can you get uprated versions of these or is a standerd part?
Hi
As far as I'm aware they are just a standard part. They are cheap and easy to fit.
Regards Chris
about 5-10 quid at a guess from a good automotive place.... [ like mineemoticon-0110-tongueout.gif ]
Edited by MarkMac
Yeah would be great and cheap...if it wasnt for the fact at the same time im having the a new sachs clutch and jabba flywheel fitted as my clutch is beggerd!
are they the drop links on the roll bar?
if so there is a new version out which is slightly shorter (or so i've read) than original and means less play.
there's information on here for part number but you should now replace the last character in the partnumber"G" for a "N" as thats the current version
http://www.fabia-vrs.com/technical-info/handy-part-numbers/
Edited by newskoda
