Whats the difference?
Hey guys (n gurls)
What is the difference between the milltek de-cat pipe and a basic piece of steel piping of the same length and bore?
Other then about £160...
Yes I know its shiny :D - what else :smirk:
None.Apart from if it is normal mild steel,it will rust.
Edited by kenny rsell
Thats a bit lol.. how can they charge so much? :o :(
That's a good point :thumbup:
Although it still doesn't stop the rest from rusting.. :(
Get a local Custom Exhaust place to make it up for you. They use 316 or 304 Stainless Steel and most give you lifetime warrenty on it.
Yeah,but it sounds like the OP don't wanna pay for shiney.
wouldnt removing the cat cause probs with the MOT ? i thought that if the car had one fitted originally by the manufact. then one had to be fitted for the MOT ? or is this not the case
From what I have read no it should still pass the M.O.T (emissions) regardless weather it has a cat or not. :)
custom pipe in stainless is still a lot less than big branded decat pipe
If it's a diesel it will pass cos diesels don't get tested for emissions, only smoke.
