Mikalor Clamp Sizes
Does anybody know which size Mikalor clamp to use for clamping the standard boost elbow to the EGR delete pipe? I'm currently using a 50-70mm jubilee but want to upgrade to a Mikalor.
I have a 55-59mm Mikalor but it's too small, the next size up is 59-63mm, do you think this would fit and clamp tight enough?
Allard quote the diameter of the EGR Delete as 57mm, not sure if thats OD or ID though, by the time you add on 4mm of silicon then your 63mm Mikalor should be fine.
its 57mm inside diametre...uses 70mm jubilee
