Adding cruise control.
I want to add cruise control to my car, what do I need to know about it and what is the best way doing it? I see Awesome offer the service for £175 odd but can it be done cheaper?
stalk and wiring can be bought of ebay for £80ish with fitting instructions
you will need VAG COM to get it activated though
Yes , Awesome will do it for £117.50 inclusive of VAT
Does that help a bit more?
Sarah
Sarah
Do you provide the stalk, wiring loom, fitting it and activating it for that price? or is it just the kit?
That is a drive in drive out price
That is the stalk , loom all fitted and activated
Sarah
i've just fitted the cruise stalk and i'm looking into the wiring side of it now :S then just vag-com to activate it :thumbup: passes the time hear at work and keeps costs down :giggle:
Cruise control kit PT No. BEA 300 003 from the Skoda Dealers is £ 66 inc vat
So Awesome's price is Very very good for fitted and activated. but a long way from Dorset
The main stealers want 2 hours to fit the kit plus charge an extra 1/2hr to 1hr for coding it and charge £70-£80 per hour
JKM in Portsmouth want £149 plus vat for kit fitted
Yes that is the right kit but at £20 more than from main dealer.
The Ebay kit supplies an extra loom this is an extension loom that goes into a connector in the bulkhead then fits the other side to the ecu.
The Main Dealer loom is longer and fits through the bulkhead with a suppled grommet so no need for extra loom.
Yeah I noticed your post after I posted mine lol. so how easy is todo yourself? I have a friend who has Vag-Com so he should be able todo it for me, if not an excuse to buy a Vag-com lead lol.
i have these instructions http://vwgolfr32.co.uk/ccs.pdf not that i can make head nore tail of them :giggle:
Its not a hard job to do just that you need to remove quite a bit to get good access have a look at the guide on the ebay supplier web site for a rough idea, its no where as complicated as it sounds and look here this will also help for airbag/steering wheel removal ect not the same car but close enough . http://uk-mkivs.net/forums/t/221940.aspx and http://www.foxytech.hostcell.net/control_stalk.htmd
Just dont rush and a dry day will obviously help and coding will take 5mins with vagcom.
your local skoda dealer parts dept can print off the BEA 300 003 installation instructions for you if you ask before buying the kit to see what is envolved with the oem kit fitting
hope this helps !
You could buy over the counter from TPS in Poole who supply the dealers for next day delivery.
Bournemouth TPS
Virage Business Park
123-4 Stanley Green Road
Poole
Dorset
BH15 3AE
Tel: 01202 644480
Opening Times
08:00-18:00 Monday to Friday
08:00-13:00 Saturday
Edited by bazaa
I took mine to the local dealer who did the whole job for £150
