Blown clutch / flywheel
Last night changing 4th to 5th about to pass an r32 ;) my clutch / flywheel disintegrated
2 or 3 metal particles came flying off the car, cars also leaking oil from the box, limped 2 miles home sounds like a train
new box, clutch and flywheel??
oh dear mate, thats going to be expensive emoticon-0101-sadsmile.gif ....
Ouch. Sorry to hear.
Sounds like new clutch, flywheel and bellhousing (if separate from gearbox case) anyway.
What would cause this!? My flywheel is rattling, only when it's cold temps though, and my clutch slips after having the map. I was under the impression it'd never go 'bang' so to speak, but is it possible?
Well there is a rivet that could have gone or I guess a DMF could have gone.
Both would have been enough to send bits of metal into and possibly through the gearbox casing at high revs.
Flywheel has rattled for quite some time, revs were around 5k lol
am just gona save
new box
spec stage 3+ clutch
smf
quaiffe diff
might as well do it right
3k's worth + labour... :peek:
Aye if you go to jabba
clutch and smf 900 ish parts
gearbox 300
then i can get it fitted for 100 tops :8
not too bad
Are you sure it was the clutch and DMF that failed. The box has a riveted crown wheel, and they can fail, punching a hole through the gearbox.
Indeed, talking of which how often do these fail and how easy are they to have inspected and replaced at clutch change time if required.
Well previosly the clutch never ever slipped but the dmf rattled its nuts off it was like a train
now fifth gear is unselectable the noise is mental and bite is all over the place??
Whatever the story i know im going to need a new box clutch and fly :(
They don't fail often, and usually only if the car is sticking out crazy power. It's a gearbox out and total strip down to check them. Kit available that replaces the rivets with high tensile steel nuts and bolts.
gearbox 300
not too bad
lsd diff?
mine wasn't slipping, but gear selection was patchy (at best), it did make the odd weird (metallic?) noise and bite too was all over the place at times. allytech has a picture of the friction plate that he took out yesterday... :S you can get a Helix kit (including SMF) for not too much money
lsd diff?
rude not to :D
lsd diff?
Optional ;) if i go diff too it will work just over 2 k
5k? :o surly the internals of the engine are not designed to rev that fast? :o
gutted buddy, what power r u running? were u on a standard clutch thing ur running the same set up as me
Edited by felix_19
230bhp
was running a sachs with dmf
i think the dmf has exploded lol!
rude not to :D
By the time you add the vat, and take off our 5% jabba discount, they come in at around £50 difference for either that or the sachs
Matt
Helix ftw!!
They dont put em in all the rally cars for nothing ;)
Helix ftw!!
yeah...you said... B)
