central locking worry on vRS!
Hi guys, came across something worrying tonight. When i lock the car on the remote and try to open the rear doors, the doors open and then sounds the alarm, but ive tried the front doors and the bootlid and they stay locked/shut.
any help appreciated
tim
tim
Disconnect the battery may reset it check the fuse box
Lock the doors from inside and ask somebody to check if the rear doors open if they still open its not the remote..
Looks like electrical related issue
Keep us posted
1 fault stored in central locking on my vag com
01598 - Drive Battery Voltage
07-10- Signal too low - intermittent
Cars Battery is weak/ the remote batterys are tired?
Mine does this, however its only on 1 door. All the rest are locked apart from the driver side rear door. As soon as opened it sets off the alarm.
  • 5 months later...
Finally gave up on this after trying lots of things, so booked it into my local vw dealer, they checked everything i checked, fault memory, locks and wiring all ok? so they delve further in and found that the cars central convienvce module thinks my car is a 2 door so they reprogrammed. its all ok now, can only think its been like this since thge factory or its since i played around with the beeping and unlock all doors function on the vag com
Mine does this too!
