vds pro in manchester
i was hoping somebody would have vds pro in manchester so i could change a few things on my mk1 octavia vrs.
vds pro or vcds?
What are you trying to change?
vds pro or vcds?
i wnat to use my keyfob to let the windows down which is what i need vds pro for and anything else vcds cant do)which im hoping someone with vds pro can tell me).
Chris,
As I said in your other thread, I'm only 40 minutes or so away from you. I don't know of anyone any nearer to you, unless Stafford is.
Get yourself over the right side of the Pennines!
Chris,
i will do one of the days
If you need anything doing with VCDS, I am in Dukinfield and can help out mate!!!
nice one mate.i need the seat belt chime turning off.
Chris,
which part of bradford are you in.
PM me, and I will pass on my number if you want to keep it in case you need the help!
I am well known in the VAG world, in most cases as CHRIS VAGCOM!!!!
Wibsey, less than 5 minutes from J26 of the M62.
