Snow Foam - I know this is a silly q but.........
Hi
I know this is going to be a stupid question but..............
Smog Monster mentioned the other day about this snow foam stuff and I looked into buying this but it mentioned I needed the lance, I don't really have the spare cash to spend 50/60 odd quid on a lance to go on my pressure washer and my washer is so old and gives me vibration white finger so I tend not to use it just the old fashioned hose so would need a new one, do I actually need it or could i just get away without it?
Thanks for any info
Tony
You need to buy a lance so you get the correct ratio and mix of snow foam with the water, cant just use a normal hose you need a jet wash, its well worth saving up for one though makes a difference when you come to clean your car though
Edited by Thurlby12
So will any lance work If i could afford a pressure washer with that type of lance and bottle thing or does it have to be the one they make?
My link
would something like this be an acceptable option?
My link
http://www.argos.co.uk/static/Product/partNumber/7151079/c_1/1%7Ccategory_root%7CGarden+and+DIY%7C14418702/c_2/3%7Ccat_15701041%7CPressure+washers%7C14418805.htm?_$ja=tsid:11527%7Ccc:%7Cprd:7151079%7Ccat:garden+%26+diy+%3E+pressure+washers+%3E+electric+pressure+washers
Right money and a little more robust !
To be honest it is best to to invest in a Snow Foam Lance as it makes the job so much easier!
Save your pennies, it's only for heavily soiled cars. Just wash weekly during the summer, add a squirt of quick detailer and an MF cloth every 2nd morning (takes less than 2 mins to nip round the car doing only the bits where you can see dust / muck) and don't let your car get manky :thumbup:
It's little / no benefit for cars washed weekly.
I TOTALLY disagree with your comments.
Its NOT just for 'heavily soiled' cars at all.
I use mine at every wash, even light dirt..It saves touching the car , ensuring that all particles are removed..the way to reduce/eliminate swirls.
Then wash normally or simply dry it with a MF towel
I would never use QD on a 'dry' car either.
Your call ...Its your car.......but please dont advocate this to others as IMO its flawed advice.
Thanks for the comments guys, I think i'll invest in a new pressure washer and then maybe the lance thing at a later date!
The snow form does look very tempting , even if without the lance its not perfect but they :) I have ordered some Autobrite snow form off ebay and will get pressure washer! wonder if it makes a diff we will soon see!
You wont get the "foaming" effect without the lance really.. I tried it recently and was disappointed..
Save up and get a lance.. I am getting one when my vRS arrives.emoticon-0148-yes.gif
+1
Ok one expense at a time haha :) unlesssssssss anyone has a spare one up for sale cheap :D
Why? its really quite good advice. :)
Just rinse the car first then use the 2 bucket method with a decent (lambs wool) wash mitt and this will be fine. :)
It is never good advice to tell someone to rub dust into their paintwork..emoticon-0145-shake.gif
in case you missed that ill make it clearer by typing it in caps :yes: RINSE THE DUST OFF FIRST. :dull:
Thats not what you said in your original "suggestion"
But
as ChrisRS has said
Your car
Your Call.
orly ? :dull:
Edited by Thirdtimeluck
orly ? :dull:
oops
My bad..
Wrong poster
oops
My bad..
Wrong poster
hehe nps mate ;):)
Foam lance is only way to go if you want a good thick foam, the karcher foam gun (about £15) and pressure washer inbuilt detergent tanks are a complete waste of time in comparison. Expensive but worth it.
I find snow foam excellent for removing nasty gritty dirt before a proper wash (if the car is covered in it) or good for a quick touchless wash when you have little time.
It's not a perfect clean, but it's pretty good :)
has no-one suggested a Gilmore to this guy? an attachment for your hose. Doesn't give results as thick as a PW and a lance, but does a good job
whats a gilmore?
I got a thing free with pressure washer that was the bottle and a nozzel thing that attaches to pressure washer seems to do a good job !
whats a gilmore?
Similar to a snow foam lance only it works from your garden hose.
I hear you need very good water pressure for these to work properly.
Hence
Go the pressure washer/foam lance route
Edited by vectra1
