vag codes debugging
Hi Could someone please help with the following vag codes
PO172 - Engine light - System Too Rich (Bank 1)
00301 - ABS Return Flow Pump damage
Any inputs as to what cud be the potential issues and where shud i start investigating will be very helpful !!
Many Thanks in advance..
P0172
* Fuel system
* Excessive fuel pressure
* Leaking or contaminated fuel injectors
* Leaking fuel pressure regulator
* Low fuel pressure or running out of fuel
* Vapor recovery system
* Air leaks after the MAF
* Vacuum leaks
* Improper seated engine oil dipstick
* Stuck EGR valve
* Oil overfill
* Cam timing
* Cylinder compression
* Exhaust leaks before or near HO2Ss.
00301
* Fuse(s) faulty
* Wiring and/or Connector(s) from/to Return Flow Pump (V39) faulty
* Return Flow Pump (V39) faulty
thanks mate, i am investigated this, can anybody recommend a good skoda/vw mechanic in reading/ berkshire..
I would want to avoid the big names ( obv to avoid a big bill )..
Thanks in advance..
