Pre-Cat removal on TFSi Octavia II
Following on from vRSy's recent post (see here:http://briskoda.net/forums/topic/165168-tfsi-stage-1/page__p__2018438__fromsearch__1entry2018438)
I would like some more information about carrying out the Pre-cat removal on a 2006 Octavia vRS TFSi (BWA engine) , what part numbers are needed for gaskets bolts ect
Here is a diagram of the exhaust system (from a Golf so maybe different):
Here is a key to the numbers:
1. Nut, (4 off) Replace, Coat stud bolts on exhaust manifold with hot bolt paste. (40 Nm) Part no - N 102 861 08
2. Catalytic converter, with front exhaust pipe, with flex joint.
3. Oxygen sensor, behind catalytic converter
4. Retaining loop
5. Nut. (25Nm)
6. Rear Muffler
7. Support ring
8. Bolt. (25Nm)
9. Rear clamping sleeve
10. Centre muffler
11. Bolt. (25Nm)
12. Front clamping sleeve
13. Nut. (25Nm)
14. Support ring
15. Support ring
16. Gasket, Replace. Part no - 1K0 253 115 AB
17. Heated Oxygen sensor
The parts that need replacing are number 1 on the diagram, 4 off nuts, and number 16, the gasket between the turbo and downpipe.
Does anyone happen to know the part numbers for these parts?
If anyone has already carried out this modification, are there any replaceable parts that I have missed out?
Any help would be appreciated.
Edited by Bogwoppit
i re-used my gasket when i replaced my pipewerx DP. all im going to do is take a hammer straight to the cat and bolt it straight on again
Part numbers now on the first post.
