upgrade turbo hose
I have an issue with my turbo hose as it has popped off for the second time.Obviously this is quite annoying and wondering instead of having to get the garage to keep sorting it if i could get an upgrade?
theres a few mods....4 self tappers drilled into hose/connector....4 cable ties....1 round hose and connector and 2 holding together.
When mine went, the collar/lip around the end sheared off - this may be why yours keeps popping off. Plenty of workarounds as above, however the new part is something like 80 quid plus fitting...
What hose do the octavia vrs have?my boss has one and told me he has never had any issues with his.Would a jubilee clip on the hose help at all?
not on a fabia as the hose has an internal metal sleeve built in..so the connection is actually metal/metal with a rubber o ring sealing it and a clip holding the pipes togther..
ive got one on order from samco for £110 with alloy billet ends because i was in the same boat as you,let me know if you want the part number
is this a straight swap?
what is part number please?
call to Gary at Merlin Motorsport (01249 782101) he will sort things out for you just quote him the part number (TB2826)
you may need to order 2 new clips from skoda.
i better add that it takes 3-5 weeks to make it so i have not got mine yet
Edited by bluepassion
Why not just buy a stainless stell boost pipe off here, then buy a 90 degree bend for the top that connects to the egr valve, and a sleve hose to connect to the original intercooler pipe? Costs about 40 for the boost pipe and 15/20 for the hoses. Looks great and cheap replacement for 60 quid instead of dealer price or samco one
Elliott
dont think that would work because it would still keep pooping out from the intercooler
could smell a bit as well..:giggle:
