Viewing ping results
A simple question. Using Windows 7, when I ping an IP address using the Search programs and files box - e.g. by typing the command ping 192.168.0.110 - the results disappear off the screen before I can read them. What do I need to do to get them to display long enough to read and/or copy?
I think i follow what you're doing.
Instead of typing in ping there, type in "cmd" and hit return, then in that window that opens type in your ping / tracert etc.
Or have i misunderstood your question :thumbdown: :'(
Exactly the info I wanted. Many thanks. :)
And i'm still nowhere near reaching today's top poster's board even with jumping into the bits of the forum i never normally go to :giggle:
Ho hum. :giggle:
Glad it's sorted DGW :thumbup:
EDIT: that did the trick! I am no officially on the front page of briskoda right now, cheers DGW! :giggle::thumbup:
Edited by Mute
Unfortunately I can't help with any more questions for you to answer at the moment. emoticon-0106-crying.gif
if you want to run the command in one go, you can prefix it with cmd /k which will fire up the command window and run the command - for example cmd /k ping www.google.co.uk will open up a command window and start the ping command. Another useful feature is being able to pipe the output to a file rather than the display which is handy if you're running a longer test and want to store the result. For example to continuously ping google and store the results in a text file the command from the run box would be cmd /k ping -t www.google.co.uk > c:\ping_test.txt which will open a black box with no text which will sit there until you press Ctrl + C which will stop the ping command and the results will be available in C:\ping_test.txt
John
If it's a problem with hacks -Synantec used to offer a facility on line to trace hackers -and at one time had maps of the world's prime would be hackers .Or alternatively - you could try a look on tucows.com /download.com on IP TRACERS .
