Got a FL vRS and maxidot?
Have you got a FL vRS with maxidot? If so does your oil temp give a reading? Mine just shows ---
It only shows the temperature once it gets over 60C, are you doing short journeys in your car? It takes about 10-15 mins for mine to register a temp (diesel).
I am doing long journeys and it still says ---
Must be something wrong then. Need to get the workshop to take a look
yep, mine works fine (2010 petrol vrs)
Mine works fine too, CR DSG, shows --- for a few minutes until the oil is warm enough to resister a temp and once up to temperature when running seems to fluctuate between about 98-105 depending on how hard the engine's being worked
