Solar panels, amps, watts, volts and confusion!
Ok then... lets be having all you electronic calculation boffins then!
Basically what I want to know is how can I achieve the following:
I want ~12v
I want ~5-6 watts
I will be mostly charging devices at 5v requiring 2-5 watts
Is it possible for me to connect multiple, smaller solar panels together to achieve the above? I am wanting to do this as it is then smaller once I get the panels into some sort of folding frame type thing! :smirk:
for example. 4x 6v 1 watt panels. Could I connect two in series (takes me to 12v) then connect the other 2 in parallel to the other 2 which would then still give me 12v and 4 watts or is it not that simple?!
Any help greatly recieved as I am just getting confussled by all the equation to convert between volts, watts and amps.
I'm good at wiring etc just not the whole technical side of it! lol
Phil
I = P/V
P = V x I
V = P/I
P = Watts
I = Amps
V = Volts
Hope i remembered them correctly it,s been 40 years since i used them.
Thanks that is a bit helpful.
I think the thing that is really confusing me now is that if I am getting 5w at 12v from a panel then how many watts will I get at 5v?
You'll still get 5W but at a different Amperage
I=P/V
I=5/12
I=0.42A
I=5/5
I=1A
So you'll still get 5V but now at 1A rather than 0.42A
+1 for high school physics :thumbup:
Careful of what your charging, Li-ion batt's are a bit sensitive to power :thumbup:
I = P/V
P = V x I
V = P/I
P = Watts
I = Amps
V = Volt
And to confuse a little more
P = I x I x R
AND P=(V x V)/ R
R=RESISTANCE ( in ohms)
Comes from using Ohms law ( V =I x R) on the first formula and transposing etc .
