radio
54 fabia. after having radio stolen, and fitting a new one of a different make how do i wire it so i dont lose station presets after removing ignition key
Edited by pop63
Did you get a digital radio, as analogue signal switched off 2015 or there abouts.
Hi pop63 !
Does the new radio have the same connector as the old one? If you use a reduction to ISO connector then you have to flip two cables, Check the manual. I think it was a yellow and red.
def yellow and red wires to switch round. most now have bullet connectors so its an easy switch over.
