Octy II centre console
Doe anybody know how to remove the console between the seats as my central locking button has ceased functioning (bloody stupid place to put it anyway, right beside cupholders). I've had a poke around but can't figure out how to get it out. Thanks for any advice.
Edited by thurian
Pull the plactic gear gaither off mate, put your hand thru and pull the wire and unclip it.
Sorted!!
Happened in my mk2 the other day
G
Dead easy remove gear lever gator and press the switch downwards through the hole its fitted in and you can pull the switch and cable through the gear lever hole. replacement is in reverse. no need to remove the centre console!
Edited by sherlocks VRS
Sorry, should have mentioned I've a DSG, doesn't seem to be enough room around shift mechanism to get fingers in.
