pics of my blackline
eh? no pics or link mate :thumbdown:
there is now, sorry having a bit of trouble.
btw the other cars were also mine at one time. i sold the astra 2.0 to buy the celica which blew a head gasket recently, couldn't afford the repair so now i have a skoda favorit blackline.
Edited by bebop256
That looks very tidy mate. :thumbup: Like the look of the other cars too. :)
Hey this car was on e`bay last week with the exact same pictures,your the buyer?
Edited by WeekendMechanic
Well if I bought a car off the bay I'd save all the advert piccies :D
yes it was.
the guy wanted £700 buy it now but said the reserve was a lot lower. the bids only went up to about £200. as i was desperate for a cheap runaround i offered him £300 and he accepted.
it was all a bit dodgy though.
only one mot a v5 and a few recent receipts.
the v5 was registered to a disabled driver so had a problem gettoing it taxed. and have since found a some past mot's from the vesa site with a whole load of welding done and other stuff.
car drives and looks great though. despite the few problems. the gears are positive and smooth the interior is very clean. and just a couple of minor dings with some rust on the hatch.
it came with a new battery, ht leads, distributer, and exhaust system.
Edited by bebop256
You asked for test history information for vehicle registration L650RYJ. You provided test number 401235819429 to confirm that you had a legitimate interest in the vehicle. If you do not have a legitimate interest in the vehicle you must destroy the document. This information is correct at 14/07/2010.
There are no later tests for this Vehicle.
________________________________________
Most Recent Vehicle Details and Test Summary applicable to this test number.
Registration mark:
L650RYJ
Make/Model:
SKODA / FAVORIT
Colour:
BLACK
VIN/Chassis No:
TMBAEF200P0781795
Approximate date of first use:
31/08/1993
Type of fuel:
Petrol
Date of test:
11/11/2009
Certificate issued (Pass)
Odometer reading:
44,427 Miles
Test number:
401235819429
Test expiry date:
10/11/2010
Full Test History, starting with first recorded vehicle and test results
Registration mark:
L650RYJ
Make/Model:
SKODA / FAVORIT
Colour:
BLACK
VIN/Chassis No:
TMBAEF200P0781795
31/08/1993
Type of fuel:
Petrol
Date of test:
28/08/2007
Odometer reading:
40,390 Miles
Test number:
294580647283
Test station name:
SETYRES AND EXHAUSTS
Test station number:
7439AA
Test station telephone number:
01903752689
Test class:
IV
Test expiry date:
27/08/2008
Advisory Notice issued
Offside Front inner wing Suspension component mounting prescribed area is corroded but not considered excessive (2.4.A.2)
Nearside Front Shock absorber has slight corrosion to the casing (2.7.2a)
Offside Front Shock absorber has slight corrosion to the casing (2.7.2a)
Offside Front constant velocity joint gaiter deteriorated (2.5.C.1a)
Date of test:
07/08/2008
Certificate issue refused (Fail)
Odometer reading:
43,847 Miles
Test number:
414690528278
Test station name:
7439AA
01903752689
Test class:
IV
Reason(s) for refusal to issue Certificate
Nearside Rear inner arch Suspension component mounting prescribed area is excessively corroded (2.4.A.2)
Nearside Rear inner sill Suspension component mounting prescribed area is excessively corroded (2.4.A.2)
Nearside Rear outer sill Suspension component mounting prescribed area is excessively corroded (2.4.A.2)
Offside Rear inner sill Suspension component mounting prescribed area is excessively corroded (2.4.A.2)
Offside Rear inner arch Suspension component mounting prescribed area is excessively corroded (2.4.A.2)
Offside Front Front constant velocity joint gaiter split (2.5.C.1a)
Centre Exhaust has a major leak of exhaust gases (7.1.2a)
Offside Front inner edge Tyre worn close to the legal limit (4.1.E.1)
Advise offside front lower arm bush/mount bent
Advise steering rack moves slightly in its mounts
Date of test:
03/11/2009
Odometer reading:
44,412 Miles
Test number:
241317909301
Test station name:
CENTRAL AUTO REPAIR SERVICES
91322
01903 207219
Test class:
IV
Windscreen washer provides insufficient washer liquid (8.2.3)
Offside Steering rack gaiter split (2.2.D.2d)
Offside Front constant velocity joint gaiter split (2.5.C.1a)
Offside Front Shock mount Suspension component mounting prescribed area is excessively corroded (2.4.A.2)
Rear Exhaust has a major leak of exhaust gases (7.1.2a)
Nearside Rear Shock mount Suspension component mounting prescribed area is excessively corroded (2.4.A.2)
Nearside Rear Suspension component mounting prescribed area is excessively corroded (2.4.A.2)
Offside Rear Suspension component mounting prescribed area is excessively corroded (2.4.A.2)
Emissions not tested (7.0)
Nearside Rear Shock absorber insecure (2.7.2b)
Front tyres worn on inner edges
Engine idle unstable
Date of test:
11/11/2009
Odometer reading:
44,427 Miles
Test number:
401235819429
Test station name:
91322
01903 207219
Test class:
IV
Test expiry date:
10/11/2010
Idle Unstable
Front Tyres worn on edges
This completes the test history for the above vehicle as recorded on VOSA's MOT Computerisation Database
Edited by bebop256
Surprised at the amount of welding it's had underneath, looks quite good on the outside - goes to show what matters for the MOT is what's underneath. All the other stuff is pretty much what you'd expect, and I am guessing the tyres weren't kept up to pressure.
