Water coming in behind glovebox!
I noticed water coming in yesterday because it dripped on my friend's shoe. He was then complaining how cold it was lol. When I put my hands up behind the glovebox it feels like some soft material which I asume is the firewall? Its absolutley soaked, and livin in Wales I cannot get away with leaks lol. Any ideas guys, hopin somebody else has had the same problem. Otherwise I sense and expensive garage trip. :thumbdown::thumbup:
Edited by simonhutton1
THink it'll be the plenum (sp) chamber, as it clogs with leaves etc,causing the leak or dripping. A search should bring up how to empty it, although knowing how to spell it will help too!
I think I've seen on here before that the most likely culprit is the pollen filter. Failing that check under the bonnet for bulkhead grommits being in tact. The material you can feel is the sound deadening.
To locate the pollen filter read this
Cool nice one guys, I'm gona have a poke around see what I can come up with. Right so its the sound proofing. The guy I bought it off left the car standing so it might well be clogged with moist leaves as it was sitting under a tree. Doh! Thanks again everyone, you guy's rule! :thumbup:
Ok, managed to locate the plastic drain thingy. Lifted the flap and oh my god. About 3 litres of water gushed out! I stuck my finger in after :p . As others have found, my drainage chamber is full of like black muck. Would you reccomend I take it to Skoda Sinclairs to get it all cleaned out? :wonder:
If you've got a pond vacuum type thing or anything, could try that? If not I'd take it to an indy or something, will be cheaper - but clean it out anyway.
We do. :)
I've just found more threads on this, some people say to poke it out myself? I'll give that a try and hopefuly no further water invasions. Also somebody mentioned there was one of these rubber drain things on the driver's side aswel. I can't for the life of me find that one however. Possibly a topic to be pinned I would say. Its a common fault afterall. :thumbup:
My garage used brake cleaner to shift all the shyte in there when mine blocked up! Just make sure u keep it off your paint if you use that though! Oh and remember to order another pollen filter , mine was absolutely sodden!
Oh gosh yeah, good point man. Haven't checked the pollen filter but I'm sure its f'ed. I'll pop that on my to-do list. Thanks Dmac :thumbup::thumbup:
