1.4 8V problem
Hi all, just wondering if there any common issues similar to this one. Friend has a 51 plate low mileage 1.4 mpi 8v Fabia, she went over a bump and it stopped. I've been to see it and there doesnt seem to be any fuel pressure. 1st thing I though was the emergency fuel cut out switch but I can't see one of them! Any suggestions before I start buying parts?
Many thanks in advance.
Check fuel pump relay is seated correctly.
Cheers, that was one of the possibles which I'd thought of, before I dismantle the dash, where about is it?
In all honesty I am not 100% sure on a 51 plate. Will either be on the fuse box panel, or if not there, above the drivers side parcel shelf just to the right of the steering column.
