1/4 mile racing
hello all gunna be take my 4x4 turbo on the strip in the next month anyone else done it yet and wt times did you get iwant 16's
im taking my vrs up the strip at usc next weekend :)
kwl good luck i hope u beat some jap craps ass :giggle:
If stock I would expect high 16s, maybe with rear seats out. If remapped, that would be 200+bhp no? Then I would expect at least high 15s.
Not done one in the vRS but did a few in my old saxo VTS. My best time was a 15.2 dead
I feel if I'd have run after I stripped it out and fitted the fg panels and polycarbs I could have seen the 14s
You'll be amazed at how heavy the rear seats in the Octy are, the folding back sections anyway (the seat squabs are light as anything).
We took the rear seats, spare wheel and tools out of Simons Octy at Combe earlier in the year and it saved a hell of a lot of weight, not great on a track though as the back end was skipping about in the corners.
As you say taking heavy parts out of the car particularly from the rear end can make the car prone to unexpected oversteer and back end 'skip' where it starts to feel a bit flighty and twitchy. If you are running 1/4 miles this is no problem and be quite a significant gain however come a track and it can all get a bit unpredictable. If you are looking for a longer term idea then try moving the battery to the rear of the car, to balance the weight a little better :)
Top gear done a test online (not sure if it was aired) where they got a bog standard Pug 207 gti (iirc) and done a lap with stig at the wheel. They then stripped about 150kg out of it, a significant weight considering the car is about 1300 kg Done the lap again and he ran the exact same time as the car might have been a bit quicker off the line but come the corners it was out of control and unsettled. It was in the wet though so the effects of lift of over steer were made greater
Edited by Lew_VRS
I have found good handling gains from removing weight off the front and transferring to the rear - mainly the battery. I don't really suffer from too light a back end thankfully. Maybe I'm not trying hard enough. I often have the spare wheel in the boot as well though, but from this friday the battery is going in there from the boot floor, so I will be a bit lighter again.....
Also, passenger seat was removed for my 13.7 run. I tell you what, golf GTI front seats are not light! :D
14.5 at 100mph terminal, car fully loaded with camping gear, interior etc at pod ;)
Impressive times mate :)
not bad on cheapish tyres fully loaded eh. was first run too, be in the 13s next time no worries
Fair play to you mate! Keep going at it!
had much work done to it?
Would like to see what times you get on that one :) do like the 4WD Octys :D
Have you done much to it for fairly standard?
Mike
hybrid k03s
forge front mount
turbo back system
440 injectors
panel filter
007p
map
getting a new mani soon too
inlet or exhaust?
Does the hybrid K03S fit on a standard exhaust mani?
inlet or exhaust?
Hybrids are designed to be a direct replacement so yes they should but with a performance exhaust mani this can help spool and increase power :D
It is a nice mod list :D
Mike
exhaust mani, yeah k03s hybrid looks the same and fits the same as standard, just the inards are different. mani's are meant to make a nice difference on them
do you know if they do an equal length mani for the hybrid?
Mike
its standard ecpt remap and 007 dv
my car run today 15:40 at 84mph
not bad mate!
i expect the extra traction helps! i can run a terminal speed of 96 but only do a 15.21. seems to be a higher TS than some but traction from the line is my main downfall!
not bad mate!
was awesome off the line firsttime using it like that and omg i was impressed what has your car hade done man i Think im losing alot of time from the amount of squarting it dose but i beat a caterham kit car up til 3rd gear tht run a 15;00
so with abit more power i wanna brake into the 14's
not bad mate!
what engine mods u hade done
i have run a 15.8 in my vrs estate with everything in it i have induction, fmic, and still havent done my remap was laggy as hell but the upside of it was when the boost dose come in its one lump of power then just keep the blower going!! lol
  • 2 years later...
just managed a 15.0128 today with my stage 1 map and full exhaust!
