Felly Alarm System
I've bought a 2nd hand felly Estate and it's had an alarm fitted, a Volkswagen Logic 600. I can't find much out about it expect it's normally mounted behind the instrument panel in the dash.
This wouldn't be a problem but I accidentally set it off today, and when I bought the car it didn't come with any remote I would expect for the alarm. I've got an instruction card that was left in the glove box and a small 'raffle' system ticket that has a code on, it was tucked behind and under the radio, I'm thinking this might be the code for linking new remotes to.
Has anyone got a full user guide, ideas as to where to get replacement remotes, details for safe removal etc?
I also have one door with a different lock barrel to the rest of the car. How easy is it to get matching barrels made?
do you have a barrel key that will turn the alamr off on the unit itself??
or just cut it all out most of it will be behind the glovebox should take rocket science to get it off, oh and dont worry about the immobiliser as the ign key has a chip in it so the car can not be started without the key anyway.
took about 5 mins to remove the alarm from my road rally felly
Sadly I don't have a barrel key to deactivate the alarm box, all I got with the car was a single ignition key and a 2nd key (rather thinner but still a Skoka key, I assume from a different model) which does the driver side door.
If it's the same alarm as on Golfs I suspect VW forum users may know more about it :)
