Engine mount play
I noticed a knocking sound when I drive a little harder and when changing gears from first to second in my Karoq 1.5 tsi (manual), and knocking sounds over bumps and the speed bump, I did a movement test but in place, is it normal for the engine to move like this and knock on the mount or should I replace it? it's a hydraulic mount.
Video is on my car. Pictures are from web, new mount distance.
https://photos.app.goo.gl/LkhX6nHXugVktT3Q6
Edited by imart143
Dont think it should move that much. Havent come accross hydraulic mounts before but reckon it should be tighter than in the vid. Is there any sign of fluid underneath?
Alasdair
My BMW 740 Sport has "hydraulic" engine mounts that eventually lose the fluid which is actually more like a gel. The engine then drops onto the cross-member with consequent 'orrible vibration. Should be an easy swap, unlike the BMW which are a b*gg*r to get at because of the exhausts....
There’s no oil around it, but my previous car—a Renault Megane—had a mount like that too; it was soft and wobbly, whereas it had been firm when new. The Škoda is 7 years old and has 100,000 km on it.
Reckon that amount of play is excessive especially as your getting a knock. I would get it changed or at least looked at.
Alasdair
Check the other mounts as well as if one fails it puts more stress on them including the gearbox dogbone mount.
Alasdair
From memory bolts may be stretch so should be replaced at same time. Did my sons fabia gearbox and reused bolts and no problems after 2 years though.
Alasdair
Those bolts are in 10.9 class. Tensile strenght 1000 N/mm² which is high strenght, to get it to plastic deformation, much more torque needed than aluminum block can endure. I dont think i need new bolts. Not for aluminium mount. Old ones are good enough.
It that place, when changing timing set belt, you have to change 50 bolts which is insane.
Edited by imart143
i put new hidraulic mount, Lemforder, and on lower mount i put powerflex yellow insert. now engine runs in idle like a diesel, but i think it will settle down more after a while. hidraulic mount had bad play, new one have almost not play at all..
https://photos.app.goo.gl/4hDEtQ2Q3wDCwcx7A
after a while, vibrations made me have headaches, so i modified insert, i was browsing internet and many people did similar, i cut out some elementr to increase motion from zero motion with full insert, it is not drivable. this is another level, no more vibrations on start and 2 cilinder mode, but holds well on speeding and sporty driving..
Edited by imart143
