any tips?
Just bought a VAGCOM cable and downloaded VCDS lite got it working no problem main reason i got it was to read fault codes of which there where 2 one being the battery voltage being to low which i thought was an issue when my dash lights all came on a few months back and the other a rear wheel speed sensor probable from the rolling road day ive just done so i have cleared them i think.
Is there any way to veiw real time data engine performance boost pressure AFR ect ect on the VCDS lite if so how would i veiw that?
Any other cool things i can look at as well? or advice?
thanks in advance
simon
simon
Live data is viewed using Measuring Value Blocks. There is a manual online for VCDSLite and you should read about the Measuring Values there.
As to cool things you might do, check the Ross-Tech info page and the Ross-Tech Wiki
You also need the full activated version to perform some things
