Two DPF regens in 3 weeks!
This to me, doesn't sound quite right.
First one I took it into the garage and they did the regen for me. I did the other myself last night after a drive down the motorway for 10 minutes.
The car is a 2008 vrs (PD) and only done 27,000 miles.
Anyone any ideas - or shall I just get the DPF bypass done?
Cheers,
Andy
Cheers,
Andy
Has the car had the 26E6 campaign carried out by the dealer? This provides a new map for the ECU and replaces an exhaust pressure sensor so that the DPF is managed better by the ECU. I used to own a PD Vrs and it used to regen frequently before the 26E6 mod was done. If not I would get it done ASAP.
If you have had the 26E6 mod done, I would, suspect a faulty exhaust pressure sensor.
I agree. And if it is the exhaust pressure sensor this will still affect after a de-dpf. Mine went into limp home after a de-dpf and the sensor was to blame.
Well, I have had a remap done by Ben @ Shark this weekend, so is this likely to be picked up by them or will them doing this revert it back to the original map?
