what have i done? disconnected battery and all dash warning lights are on
I finally found the can gateway which i disconnected after disconnecting the battery now all dash warning lights are on. I have not doen anything to the car except diconnect the battery then the can gateway?
There is a
Steering wheel
TPM
Airbag
ESP
also maxidot is saying fault airbag fault esp
There is a
Steering wheel
TPM
Airbag
ESP
Dont know about the airbag, but all the other lights come on when I have disconnected my battery in the past. A short drive and they should all dissapear.
Just drive the car a few metres and they should go out.
they have all gone out except the airbag.
find somne one with VAGCOM just to check it. Might be as simple as a reset?
Edited by vRS Dovit
Helpful information, thank you contributors
Yes they will all go out apart from the airbag, you will need either VCDS or a dealer to reset it.
ive just ordered a vag com as i will need it to code the ops anyway. how do you reset faults?
cheers for help guys panic stations when my dash lit up like a christmas tree
Did you order the genuine interface or an ebay jobbie? As you need the pukka thing for CAN based cars.
After you have done a scan, save the scan then click on the (IIRC) 'reset' button - it's pretty straightforward and obvious when you do it.
ordered the real thing 204quid for the usb micro can. the list of things im retro fitting is getting longer so thought i should get one as it will be easier than finding someone with a vcds. ok reset sounds simple enough cheers for the help.
