1622 P0238 fault code
Hi,
I have this fault code and can not get rid of it. My friend tried as well and could not.
Did anyone come across this? If yes, I would appreciate a tip how to solve it
Many thanks
Are you a digit missing from the code?
16622 - Turbocharger Boost Sensor (A) Circ High Input
Ross Tech suggest checking the MAP sensor and associated wiring
Yes, indeed one digit got missing 16622 .... well spotted... I shall check the sensor and the wiring... and let you know
  • 5 weeks later...
Was this a MAP sensor fault? I got the code 16622 today
Yes mate. It was the MAP sensor. I cleaned it and drove a day but the fault come back. At the end replaced the sensor and all is fine since.
Good luck.
Good luck.
It is a very easy DIY job. I removed the headlight, 15min and done.
Good luck.
I cleaned my MAP sensor 3 months ago and it worked good until today. I think its time to change it now.
I would say so mate.
Hi !Will someone please put a good picture with the map senzor and with its loation on the octavia1 vrs auq engine?!Thankyou!!!
Nobody, huh!!!?...
Here is a picture of me unplugging it, it is located on top of the intercooler. The big hole is where the headlight usually is.
Edited by chicken_eyebrow
Thanks a lot !!!
