Water Leak
Just got my car back from 30K service and the the spare wheel well was full of water. Guy at garage said two rubber vents had split and were letting in water.
Anyone else had this ????
Had the same about a year ago.
If I remember well, a broken seal above the passenger door was the cause...
These were seals just behind the spare wheel.
Had the same problem with the boot as well on my Fabia 2 1.4 TDI - boot filled up twice nearly to the top. Also the lockable fuil cap needed replacing.
My biggest problem is the Skoda dealer, to say they are jobs worth is an understatement!
  • 10 months later...
I've got the same issue with my Fabia II, Tyre well full of water .......... do you remember the name / Part numbers of the seals ?
The old MK1 Fabia VRS used to have the washer pipe pop-off in the tail-gate and leak downwards when tail-gate washer was used.
