Another locking question...
Morning ladies and gents, I'm looking for a bit of help.
My passenger front door deadlocked itself shut, removed door card and took old lock motor unit out, replaced it with one from eBay, plugged in the power and nothing the door still won't lock or unlock electronically.
The courtesy light on the bottom of the door is on but mirror does not work. The window has stopped working from the passenger side too (but I may have just forgot to reconnect this)
The drivers door module has no obvious signs of corrosion or damp. Any ideas?
Thanks Sid.
check the main connector for the door wiring harness as it can become corroded and damaged.
Cheers ill do that in the morning.
